GTX 570 70 Degrees Idle
20 Jul 2006
Have 2x GTX 570 in SLI, lower one runs 45 Degree Idle while upper one 70 degrees, on P67-UD7, silly layout so not slot between them..
Upper ones hits 82 Degree on Load maybe higher, is it safe?
In Coolermaster Scout case, was running both cards in Ft03 case which provided better temps, but wanted to make use of UD7
That's a huge difference in temps imo, definitely something not right there, my dad has a pair of GTX480s on air and there's no space between his cards, yet the top card is only about 10c hotter both under load and at idle.
Bottom one gets the air from front intake, where as the top one does not as the drive cage blocks any air coming from front, so air can only come from side which gets stolen by bottom card..
I might make the bottom card as default card, so top card does less work, rest of system spec does not matter, running dual monitors in clone but 2nd monitor is hardly every used..
I can't really remove cards as tight squeeze..., I'd rather get a single card, but I read the GTX 590 has lots of problems, also won't fit in case...
Would always prefer a single card over dual, I don't mind cost of single card as long as I get better performace than GTX 570 SLI
The UD7 is silly, as in order to have a slot free between cards, I have to move the 2nd card to PCI-E x8 slot which I do not mind except it is 2nd from bottom, which means that it will block USB and Front Panel Headers... so probably won't fit, it is a really bad Layout, also won't be able to Use USB 3.0 Headers as they stick out too much...
If you don't use the second monitor unplug it, your card will be in 3D clocks 24/7 with 2 monitors.
do you have a fan on the side of the case?
perhaps switching it to outake hot air, so hot air from the bottom card is drawn out of the case from the side fan
Added Side fan to blow cold air in, and removed 2nd monitor, 20 degree drop now less than 50 idle for top card,
Side FAn Blowing IN
TOp GPU: 82 degree load
Bottom GPU: 67 degree load
Side fan blowing out
top gpu: 84 dgree load
bottom gpu: 72 degree load
