GTX 570 Driver problem
9 Dec 2003
birmingham
Hi All
My headache that only started some months ago is when ever i right click anything under My Computer in the windows 7 navigation pane a box pops up saying windows explorer.exe has crashed and check online for a solution finds nothing and then restarts windows explorer.exe ive tryed new drivers and old ones back too 278 still the same thing
so ive done a fresh install of Windows 7 pro 64bit and the only time the error came up was after i installed the Nvidia Drivers, the ones that Windows 7 pro use on setup it seemed happy with. anyone got any ideas ive tryed everything i can think off
My system spec are
Intel Core i7 960 4.00GHz Overclocked
Gigabyte GA-X58A-UD3R
Corsair xms3 6Gb ram
GTX 570 Phantom
Corsair 128GB Performance Pro SSD
1TB Seagate
Samsung Blueray
Antec Quattro 850w
