GTX 580 design
12 Sep 2005
Grundisburgh
Is the GTX 580 the same design as the GTX 480. I ask to see if a 480 water block will fit or will I have to wait for a specific 580 water block.
Not sure if this should go in the watercooling section or not.
Andi.
Not yet, will have to wait to get confirmed blocks that work, EK state
the reason they make new 580 blocks is because of the different mounting holes where the mosfets are. And with a 480 block you might not get good contact on them.
