Gtx 580 or 670?
I think the resale value of GTX 580 1.5GB is a round £100-120 max after GTX 760 arrived. GTX 760 heavily reduced the resale value of both GTX670,660Ti,660 and thereby also GTX 580's.
I went from 3x GTX 580 to 3x GTX 670 and was overall a bit dissappointed with the performance increase. At it's best it would be around 20% or so but defintely not worth the price at the time.
I'd say if you can get another cheap GTX 580 then go SLi or find a used 2nd GTX 670 and sell that GTX 580.
