- 11 Jan 2011
Hi, I have a Zotac GTX 580 and I want to overclock.
Never overclocked a GPU before so were do I start?
This is going to sound silly but, what games are you struggling on with stock speeds for needing to overclock?![]()
Download MSI afterburner as said. The card should get to 825Mhz GPU without any voltage increase 900Mhz should be achieveablw ith 1.1v and a custom fan profile, i perfere using Heaven Benchmark to test my overclock as it give a more realistic load temp and for me does a good job at finding any instability.
What about shader clock?about 1600mhz without voltage increase usually?
You can't clock the shader separately on the 5 series of cards.
