Well the 6970 is not going to be faster than the 5970
Obviously you can guarantee it as well
In a lot of benchmarks the 5970 was still a good bit ahead. i think the "performance" crown is still in dispute especially considering this is one review and using old 5970 drivers. Should have a better indication when more reviews come online.
Everyone has there preferences on what they consider smooth/playable, i game at 1680x1050 aswell and have a 470, which is not to disimilar to a 480/580 though clearly a bit slower
I game with V Sync on as i really dont like all the tearing/shearing & glitching that goes on if you turn it off, i like games like BC2 and i want the framerate consistant and high, even with lots of action, i dont want the FPS jumping about between 60 and 40 or 30 etc as although it's still smooth, it does jitter about a bit when the frames fluctuate like that, and on some games this is noticable, can be distracting.
So if like me, and i'm sure i'm not alone in this, you want V Sync on and a stable 60 FPS, with minimal drops out of this sweet zone even in heavy action, then a good quality single GPU like a 580 is not overkill at all
Peoples idea of overkill varies, to me overkill would be replacing a card that can for the most part run all games at my res at 60FPS or above even during heavy action bit's with high settings and V Sync on with a faster one, as i would see very little benefit, this is why i have not gone SLI, a good fast single card does what i need at the res i play, if it didn't i would get SLI, although this would be a last resort as i really do not like the idea of having to setup profiles?? etc for dual cards and it seems like a lot of extra hassel
It's in AMD's press slides for this quarters GPU releases, they have the 6970 behind the 5970 in performance.
The review show that in most games the GTX580 is a bit fasterThe review shows otherwise and i don't know why you still get to post tbh. If i was buying i would buy a gtx580 over a 5970 if the price is around £400. There are nv fanboys and amd likewise but your points are just stupid and bring no facts to any thread. I think the mods should take a closer look at you as you are just being stupid.
With the current architectures from both AMD and Nvidia, AMD will always frustrate Nvidia becuase all AMD have to do is put two cores on a gpus and viola fastest gpu on the planet.
well the card does look impressive, but as some say its standard clocks are higher to start with, also the sli benchmarks look a little low to me, espescially the avp one as i was just playing the game with fraps running and it never dipped below 72 fps even with lots of aliens attacking me, and thats at 2560 x 1600 sli gtx480'5 @stock, how do you actually run the avp benchmark to see if that differs, cos the 580 sli results were around 45 fps which seems low.
But no comparisons to gtx480 in SLI? As I have just shown above, gtx470 adn gtx480 in SLI are stunning and your looking at 8%. You seriously calling that the gtx580 result as stunning compared to the previous cards?
However techically your better of with a 580GTX than 5970 or even a 6990
However techically your better of with a 580GTX than 5970 or even a 6990 (for example).
I am a bit underwhelmed. Moving from a 295gtx to this 580gtx for only a few fps in some cases at 2560x1600 and Crysis is still not playable at this res :/
