gtx 660 temp issue
6 Oct 2012
(do-or-die) Wye, Ashford, Kent, UK.
temps always go up to 82 and seem to stay there.
the gpu has the one fan, and i don't have any case fans.
i do have a coller fan for the cpu, but that's not really doing anything for the gpu.
atm:
idle:
temp:
42c
fan:
1050rpm
under load:
temp:
82c
fan:
2070
hwmonitor shows fans PWM, i assume that is for the cpu cooler fan?
i'm not sure if i need to set up a fan curve in something like afterburner, as i'm not sure if these reading are bad, but could be improved somehow?
the games i have been playing are 2d indie titles.
the cpu cooler is quite newly installed, and i shouls have mentioned that those temps under load only reach around 54c, so that is ok.
i could try removing the side panel then report back.
tbh, i don't know if the cpu cooler fan is blowing towards the back or front of the pc.
i have space to fix a rear or side fan.
