Been doing some resaearch into a decent laptop...
Mainly used for uni work, cad etc, but will be used for gaming
Found 2 laptops...both i7 3610, 16gb ram, etc.
The only difference is one has a 7970m with backlit keyboard+finger print scanner...
The other, a GTX 660m without the extra's.
However ! there's a.... £374 difference.
Which one to go for?! £374 for a better GPU ( did some research, is approx 2x better ) + the extra's.
tl;dr - GTX 660m -> 7970m worth £374?
Cheers.
Cheers.
