- 28 Jul 2013
(GPU in question - Gigabyte GeForce GTX 660TI OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card)
Hello everyone!
So I was letting my PC run a game and returned later on to find that both monitors were blank and the amber light was showing on the monitors rather than the usual green. Kept saying "no signal detected" when I tried to check the source.
I restarted the PC and changed to using one monitor with a VGA cable from the mobo to the monitor and that worked fine! I tried again with my main monitor using the HDMI cable (GPU to monitor) and a DVI/VGA converter thingy (again GPU to secondary monitor) and both still kept showing no signal detected.
When I changed it to use the integrated graphics on the mobo it was working fine once again and I noticed that the GPU is now not showing in the display manager and I can't even open the nvidia control panel. When I open nvidia inspector, everything is greyed out with no values/letters anywhere.
I checked the GPU and the fans do run fine when the PC is powered up and I even tried a different HDMI cable to check and that still kept giving a blank screen with no signal detected.
This base unit was purchased in Feb 2013 so I guess it's not going to be the most up-to-date!
""Titan 8200i Spinosaur" Intel Core i5 2500K 3.40GHz @ 4.40GHz DDR3 Quad Core Gaming PC". The PSU is the Corsair GS600 (600W) and has always worked fine!
Any ideas? Has it just bit the dust? I'll try provide more details if required.
Thanks
Hello everyone!
Thanks
