26 Jan 2016 at 10:04 #1 P4Clock P4Clock Permabanned Joined 6 Feb 2010 Posts 6,138 Location Barnsley 670 blocks are listed as fitting 970's, is this all reference cards? or just the cut down ones?
26 Jan 2016 at 18:33 #2 Disco_P Disco_P Soldato Joined 30 Dec 2013 Posts 6,594 Location GPS signal not found. (11) What do you mean? All the "reference" cards use the smaller PCB else they aren't reference. And therefore the 670 block should fit it.
