Hi guys,
I'm trying to get my head around how these Kepler GPU's work. I've been using this article:
http://www.overclock.net/t/1265110/the-gtx-670-overclocking-master-guide
I followed the instructions to work out what my Kepler Boost was.
During Heaven benchmark, the maximum GPU clock was 1149Mhz. My boost clock is listed as 1085Mhz in GPU-Z. According to the article, this makes my Kepler Boost 64Mhz. The GPU never went above 62c in the test and the power target is 145%.
The article says:
Unless my calculations are wrong, the maximum Kepler Boost on my card would appear to be fairly shockingly poor. Have I missed something here?
Overclocking seems more complex with these cards. I originally thought it was a case of just increasing the offset figures for GPU and memory and job done.
The article says:
Each card has a different maximum Kepler Boost. For example, some cards will have a KB value as low as 104MHz (and perhaps even lower) and some as high as 234MHz, the average is somewhere around 130MHz and 143MHz
