What's the best GTX 680 to get at the moment? I'm trying to decide
Also, why do some of the 680s require an 8pin+6pin instead of 2x6pins?
http://www.overclockers.co.uk/showproduct.php?prodid=GX-183-EA for example, where http://www.overclockers.co.uk/showproduct.php?prodid=GX-093-GI is quite close in terms of specs but only needs 2x6pins. Unless 200mhz difference really means that much difference?
Does the 8pin+6pin cards allow for a better self-OC too once you get the card?
Lastly, do you recommend the brand "KFA2" ? I've never heard of them but they look good. Thanks!
EDIT: Is this http://www.overclockers.co.uk/showproduct.php?prodid=GX-193-EA better than my first link posted also due to the extra fan? How do I know if the hot air is been pushed out of the case from the 2nd graphics bay slot or pushing down INTO the case?
and for the overclocking are both of your 680's at them clocks ? As I'm looking to purchase another 670 soonish and I'm thinking if the one I get soon doesn't overclock as well it might have to lose some performance on my first card? Which I wouldn't be interested in or do you have two different clocks for each card?
