- 11 May 2009
Hi all, I'm trying to overclock my GTX 680 however I'm encountering a couple of issues when doing so.
When I overclock the offset by 100MHz I get 1185MHz core clock when running Heaven 3.0 which would be correct since the boost is 1085MHz~ by default.
However when I go beyond this lets say 120MHz the core clock starts to fluctuate and not go above roughly 1170MHz.
Upon seeing this I looked at the power usage of the card and I noticed that it wouldn't go over 100% even though I have set the threshold to 132% and I have seen videos of people's power usage go into the 100's so I'm thinking that this might be the problem.
My power supply is an 850W Corsair and I used to power 2 x 6950's in CF. I have 4 6-pin connectors and have tried swapping them around to no avail.
If anyone can give me any insight to what could be causing this brick wall I would be grateful.
Thanks for reading.
Thanks for reading.
