Hi guys,
I have a Palit Jetsream GTX 680 4GB I would like to watercool, I have never watercooled a GPU before or made mine own loop. I have been doing my best to look around on the net for supported GPU full blocks and generally all full blocks are made for reference cards.
I have been on cooling configurator by ekwb and it says that there blocks are compatible but only says visually the problem with that is all the pictures of the PCB even for the jetstream have stacked PCI-E power connectors where as mine are side by side 6 + 8 pin. So I don't really trust the site is correct especially looking at pictures of these blocks fitted to cards doesn't seem as if it will fit around the connectors. Please if any one has got this card watercooled or if they know a block that is compatible any help would be greatly appreciated.
I also would like some advise on what components such as rads, pumps and reservoirs would be a good combination I have a 900D case so I have plenty of space and also plan on if I can watercool the jetsream going SLI.
Again any comments advise or thoughts would be greatly appreciated.
Thanks,
Chris
Thanks,
Chris
