gtx 680
4 Jan 2012
Kildare, Ireland
hey i bought this there last week...
Asus GeForce GTX 680 DirectCU II 2048MB GDDR5
i did the correct uninstall old drivers and used driver sweeper etc... prior to removing the old card
installed the new card and the screen keeps going blank. pc would restart and would get the overclocking failed beeps. (still have blank (no source) screen. the pc would boot as normal after a few seconds...
i do a hard shut down. wait a few seconds and do a startup. pc would boot fine for a few mins and the same thing would happen again.
i tried the latest drivers
resetting bios
reseating the card
format and reinstall of windows...
is there a prob with these cards? i replaced a 580gtx and the prob with that card was something similar and had to use afterburner to up voltage to 1100mv. that stabilized the card
is there a similar prob with this?
what bios are you running on the motherboard?
EDIT : latest bios version 3602 has a fix for 680's hanging with UEFI bios, might be worth a try.
download the bios ( http://support.asus.com/download.aspx?SLanguage=en&p=1&m=Sabertooth+P67&hashedid=ZYgjt71bzlh62Zk9 select your OS at the top ) unzip it to the root of a usb stick boot into bios and run ezflash from the tools section, it will pick up the bios and flash,
We have a very similar spec, and Im running BIOS 3602 and not had a problem with my 680's
Think the latest one is 3902. I tried that today. No difference. I read the crash report. Its error bcc 116 i think. Refers to driver or card itself. Using latest drivers 310.xx
Thanks for reply. Any other suggestions?
