GTX 750 TI - Hard Crash frustrating problems.
16 Mar 2011
Swansea
Hello,
So i've just upgraded to a GTX 750 TI - It's been about three days now and i've come to a problem.
Randomly, the cards seems to crash - Both my monitors just lock to a colour and i have to hard reset to fix it. I get no error it just goes on as normal after the restart.
Now my setup is two monitors one as DVI and another as HDMI(I bought the wire new but it seems dodgy as in if i even touch it the monitor goes off for a second-new one bought anyway could this be the cause?) sabertooth p69 motherboard.
Any idea on what i can at least try little stumped here starting to pull my hair out. It doesn't seem like its the card as i've tried it in games and under stress and it temp/load if fine, so no need to ask for a replacement.
If i roll back the drivers were is a reliable place to get older drivers and what do i go for? (currently on latest 364.72)
Hey Meat, below is the rest of my spec. It's old but still does what I need. On updating my bio's i'm a little scared of doing it as i've never needed to so never done it before.
-Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
-Asus P67 Sabertooth Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION **
-Kingston HyperX Genesis Grey 4GB (4x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
-Creative Sound Blaster X-Fi Xtreme Audio 7.1 Sound Card - OEM (PCI-Express)
I've tried installing older version of my drivers(362.00) But as I said I can't really recreate what crashes my computer. I'm getting a few stress test programs and will try them tomorrow.
If you have been installed 364.xx driver, most likely caused the issue. Internet is full with similar reported issues.
Solution? Not yet.
