- 11 Dec 2005
- Cheshire
To celebrate the launch of the Nvidia GeForce GTX 760 we have launched our very own GTX 760 based system!
"Titan Prodigy Proceed" Intel Core i5 4670K 3.40GHz @ 4.20GHz DDR3 Mini ITX LAN GTX 760 Gaming PC @ £999.95 inc VAT
Introducing the "Prodigy Proceed", designed for the keen gamer, encapsulated in the BitFenix Prodigy LAN gaming case in a stunning hue of green, representing the green power lurking within the "Prodigy Proceed". Rocking it's party piece, the majestic Nvidia GeForce GTX 760 2048MB. A brand new graphics chip from Nvidia has taken the GTX 760 to new levels of performance unfounded by it's predecessors. Delivering a 980MHz base GPU clock with the option to boost to a dizzy 1033MHz, the GTX 760 really does fly! Backing up the phenominal clock speed is a hefty 2048MB of VRAM allowing for unparalleled high resolution performance, paired with a 256 bit memory interface to finish the winning formula.
At the heart of the "Prodigy Proceed" you have the venerable Intel Core i5 4670K Quad Core CPU overclocked to a solid 4.20GHz, delivering a sublime computing experience. Memory standa at a grand total of 16GB running at 1600MHz allowing fora snappy and precise user experience whilst providing enough head room for extreme applications and programs to be ran. Working in tandem the high capacity memrory and lightning fast CPU clock speed display a unbeatable combination of performance unheard of in a system fo the size.
Cooling is managed by the Corsair H80i CPU Hydro cooler. Employing water cooling technology to keep the system running at a smooth and stable rate, whilst pumping supreme performance. Mini ITX size keeps the "Prodigy Proceed" foot print low and means you can easily move the system to LAN events with ease. Versatility is key with the "Prodigy Proceed", standard storage is provided by a Seagate barracuda 1TB HDD with options available to select an additional SSD and even larger HDD units for storage.
Why You Should Buy This System?
- Quad Core processing & 16GB of DDR3 memory
- MiniITX size for ultra portability and discreetness
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- Fantastically power Nvidia GTX 760 2GB with DX11 capable graphics
- All systems with an Windows 7 selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012. Not compatible with Windows 8.
System Specification
- Case: Bitfenix Prodigy Mini ITX Case Slime Green - (Different colours available)
- Power Supply: Corsair 2013 GS Series 600W PSU
- CPU: Intel Core i5 4670K 3.40GHz Haswell Processor Overclocked to 4.20GHz
- Motherboard: Asrock ZZ87E-ITX Intel Z87 (Socket 1150) DDR3 mini ITX Motherboard
- Cooler: Corsair H80i CPU Cooler
- RAM: Patriot Viper "Black Mamba" Gen 3 16GB (2x8GB) DDR3 1600MHz Dual Channel Kit
- Hard Drive: Seagate 1TB 7200RPM Hard Drive - Primary and Secondary Upgrade Options Available
- Graphics Card: Nvidia GeForce GTX 760 2048MB GDDR5
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: 20x DVD±RW Drive
- Internet: Built In 802.11N WIFI
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You? ?
Mini ITX size with full ATX gaming power!
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
Only £999.95 inc VAT.
ORDER NOW
Service Package
ORDER NOW
