Just noticed stoofa, my card is different I have this one http://www.overclockers.co.uk/showproduct.php?prodid=GX-206-MS
a lightning?
Yes the card you have, its called something else now gaming edition etc) but its basically a lightning card. I have a hard time believing its noisier than a normal reference blower. Have you tried manually lowering the fan speed? What percentage is it running at?
Guys. I think I may have jumped the gun here. having taken of my side door its evident the noisy fan is from my CPU cooler. I have a new case and never noticed it before but thinking maybe its because my 480gtx was very loud. Sorry about this. now I need good advice on a good cpu cooler. AMD.
One problem with multi-socket compatable cooler is that the ones that are known to be great for Intel sockets not neccessary means it is just as good for the AMD socket, due to using different mounting method.Guys. I think I may have jumped the gun here. having taken of my side door its evident the noisy fan is from my CPU cooler. I have a new case and never noticed it before but thinking maybe its because my 480gtx was very loud. Sorry about this. now I need good advice on a good cpu cooler. AMD.
They should be available on the 2nd of Aug according to the staff, but you should consider pre-ordering in case they got sold out before they land?
May be you can take this opportunity to pre-order one of the Manufacturer Refurbished Corsair H100 for under £40 from OcUK?They should be available on the 2nd of Aug according to the staff, but you should consider pre-ordering in case they got sold out before they land?
http://forums.overclockers.co.uk/showthread.php?t=18521571
This CPU coolers are the "all-in-one" water-cooling solution for CPU. It already has its own tube, pump and mount, so it doesn't require DIY on setting up everything yourself...all you do mount the rad to the case, install the fans onto the rad, and then mount the pump onto the CPU/socket simliar to how you would instead a CPU cooler in general.Is that for water cooled pc's?
