HI
I have a Palit GTX 760 2GB with a stock fan that is noticeably noisy above the level of my case fans.
I want to replace the fan and the most popular option seems to be to get an Arctic Accelero 2/3 fan replacement or similar but this seems to be a bit tricky to install for someone with no previous experience
Can I take the easy way out and just replace the stock fan with another quieter version and bolt the base of the card back on?
Any advice is welcomed
Thanks
Thanks
