System Spec
Asus GTX 770 4MB @ driver 347.09
Z97X GAMING Motherboard
16 GB RAM
I7 4790 CPU
Corsair CX 750 PSU
Thermaltake Chaser A31 Ghost Edition Case
Windows 8.1
So I am still having a few crashes despite following what I think is the full list of Google-able fixes suggested thus far so I hope that someone can help.
1. Nvidia Control Panel set Power from Adaptive to Performance. - This stopped the crashing everytime I booted up a game.
2. Disabled then uninstalled the Nvidia Audio driver. - This helped stop a number of crashes.
3. Changed the Power settings to turn off Fast Start Up. - This didnt do a lot other than occasionally it reboots without all of the config being messes up. Occasionally.
I run Asus' own GPU Tweak and the temperature, even after an hour of Wolfenstein, doesnt rise about 50-55 degrees. Voltage at 1150 max. Both I think should be ok.
CPU runs pretty warmly and I am looking into a better fan/cooling method than the stock fan.
RAM tested all ok.
But... the Graphics seem to just stop working. e.g. I play an hour of Wolfenstein all ok. No stuttering, pixellation etc etc. All is perfect. Then I close down the game and go do something else e.g Handbrake and off it goes into either a black screen or one with a choice of funky colours. The rest of the machine whirring away in the background but unusuable.
Pressing the reset button boots back up but pretty much doesnt work properly everytime.
Cold restart works about 50% of the time. 5 minutes later generally is the best.
So. I have been building PC's for a long time and this is the first time I have experienced this set of anomalies. I hate RMA'ing kit so I want to explore any further thoughts anyone has before sending the card back. Especially as I really want to send Windows 8.1 back... horrible horrible OS. I am not overly chuffed with the case either. Antec 1200 has been my case of choice in the last two builds but I ran out of money this time.
At this point I am happy to try out any reasonable suggestion.
16 GB RAM
I7 4790 CPU
Corsair CX 750 PSU
Windows 8.1
RAM tested all ok.
