GTX 770 Or something else.
5 Sep 2013
UK
Hi just been talking to people and have been told that the EVGA GeForce GTX 770 is not a great grahic card to buy. Can anyone tell me a bit about this? and what i should do, to buy it or to get something else. It cost around 320 pounds i can only really go up to 350 max
The people you talked to are idiots. The evga 770 is a amazing gpu. The problem is its not cheap. You could get something much cheaper with same performance. A 670 or 7950 would be as others say here better bang for buck
Are you talking to AMD fanboi's by any chance? :)
The EVGA GTX 770 is a great GPU and at a good price too.
It is more powerful that any of the AMD GPU's and will last you for a long long time..
EVGA are also a great manufacturer with a great cooler design and a long warranty period..
To be honest if you came to me and said "I have £350 for a GPU what do i do?" i'd say get a EVGA GTX 770. :D
Just called my friend an idiot and brought the card. Thanks for the advice. One question those is that i see there are cards like Gigabyte and lighting and Superclock, which one do i get as there are lost to choose from.
The MSI Lightning is the best 770 imo,but EVGA is a great choice too. Also the 770 lightning is faster then the 7970 GHz too:D
