GTX 770 Question
8 May 2013
Hi guys,
I'm wondering if anyone could point out whether this is normal, since I've not had this issue with GPU's before;
With my KFA2 GTX 770 - I am experiencing weird Coil Whining when pointing my camera at certain places in games? -
For instance, I get high-noise coil whine when on the initial boot-up screen for Heaven benchmark / This is the same case on most games, especially on Crysis 3 boot/load screens.
Then I get reduced coil whine noise (not as loud) when looking in certain directions or places, depending on what I am looking at. It gets noisy when looking close at a wall / floor.
I never really noticed until I removed my headset, and thought that I just needed to "break-in" my new card. It is still on-going.
Any info/advice? Thanks.
I have a 7950 and had similar issues. turned out that on menus and load screens I was getting something like 4000 frames per second. enabled vsync in CCC and it went away. The most noticable was when exiting Heaven on the final screen that shows up for like 4 seconds
