gtx 780 reference cooler LED Logo help
5 Oct 2014
hi guys dose anyone know where i can get the Gefore GTX Logo with led's ?
i have a zotac gtx780 so it does not have the led logo, im going to upgrade to the nzxt g10 on my sli build, and want to have the logo on the nzxt or just the led's so any help would be amazing,
cheers amatris
would need the reference cooler then pal... will have to buy one, but is "GEFORCE GTX" in green led letters really worth the money?
I mean, if you have a case with a side panel window, then its up to you... but if not, don't bother... no one will ever see it
easy answer... don't bother
Wont work anyway, as the LED is drawing power from the PCB, and since yours don't have a plug originally, well.. Nowhere to get the power from
The zotac amp is still a reference card with a different cooler, so it does have the power connector for both fans and the led
But yes, you would have to get hold of a reference cooler and dismantle it to get the led pack out, they do pop up second hand from time to time
