I've purchase a 2nd GTX 780 card to give an SLI configuration my first attempt and I'd appreciate any advice you guys can give. Specifically, I'm a bit concerned about power consumption.
My system specs are:
Equally, I've gone for an SLI configuration in preparation for running GTA V in a triple monitor configuration. I already have 2 x 24" monitors connected via DVI and will be getting a new 24" monitor to connect by DisplayPort. Since I'll have 2 sets of monitor outputs from the graphics cards, does it matter which monitors I should plug into which graphics card? Does SLI run in a master/slave situation? Should I connect all monitors to the same card?
- ASRock Z77 Extreme4
- Intel i5 3570k
- 16GB DDR3 1600MHz Corsair Vengeance
- Inno3d iChill GTX 780 (I have just purchased a 2nd identical model for SLI)
- XFX XXX 850W Silver Rater PSU
- 1 x OCZ Vertex4 256GB SSD
- 3 x 1TB 7200RPM HDDs
- 2 x DVD+RW Drives
- CM Storm Trooper Case (with fan controller for 4 case fans)
