Hello,
I cant find the reason for a 20 % drop in gpu usage on card 1 when running a benchmark like unigin heaven.
It only happens after some minutes. Both cards start at.98 % usage.
Card 1 is rated at 1032mhz and is around 3 degrees colder than card 2(bottom). Card 2 is rated at 1019mhz. Both are identical msi twin frozr 780. No overclock.
After a while card 1 drops to 80% usage at 79 degrees. Card 2 is then actually at 81 degrees and throttling slightly. I have a 4930k at 4.5 ghz.
