GTX 780
27 Nov 2009
is my psu Corsair Builder Series CX 750W '80 Plus Bronze' Power Supply (CP-9020015-UK) compatible with GTX 780???
im worry coz google giving req for amp as well, by the watt it is ok.
Ok, thanks, just make sure what i really need update.
Right now holding GTX 470, but looking at GTX 780, by the theory i'm expecting double performance gtx 780.
Do I will get what I'm expecting?
system:
Corsair Dominator PLATINUM 16GB (2x8GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit with DHX Pro Connector (CMD16GX3M2A1866C9)
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail
Western Digital Caviar Green 3TB SATA 6Gb/s 64MB Cache - OEM (WD30EZRX) HDD
Asus P8B75-V Intel B75 (Socket 1155) DDR3 ATX Motherboard
Thanks a lot
Thanks a lot
You should get more than double the performance but you may need to overclock your CPU to avoid a bottleneck.
U'll notice a big boost in performance, that mobo has a 1 x PCIe 3.0 x16 slot. Mine only has 2.0 :(
There is very little difference between using PCI-E 2.0 or 3.0, I have tested this on a number of different cards both AMD and NVidia.:)
What about tests between 1.0 n 2.0? My old 470 gonna send to uncle, he have older mobo, where does not even says 1.0 or 2.0, I suggest its 1.0 as default
And what calculation I need to take onboard to have good overclock preventing to get "bottleneck"
Here are some tests I did the other day on a pair of 290Xs, they show the differences between PCI-E 1.0, 2.0 and 3.0
http://forums.overclockers.co.uk/showpost.php?p=25282915&postcount=33
http://forums.overclockers.co.uk/showpost.php?p=25283297&postcount=60
http://forums.overclockers.co.uk/showpost.php?p=25283360&postcount=61
As to overclocking your CPU to use with a GTX 780, anything over 4.0ghz should be fine.
Thanks! Clearly explained difference!
Very happy with useful info
Wha about OC?
GIGABYTE sended me prog named OC_GURU II V1.56. But when run installation says me error 1628. kinda installshield error, but cannot fix it, looks very buggy soft
