GTX 780Ti (ACX) in a Corsair 250D
10 Jun 2013
Very seriously looking at a new build, this time going SFF.
I like the look of the Corsair 250D - I know a standard EVGA GeForce 780GTX Ti will fit inside the case, but what about the same card but with the ACX cooler - does anyone know?
Cheers.
Forgot to add, checked the manufactures site specs, the non ACX and ACX have the same dimensions but it only lists the height and length, not width which is what I'm more interested in.
It is a two-slot cooler the same size as the reference PCB with no heatpipes and whatnot protruding from it, so it should fit. However, in such a small case you may be better off with the reference cooler anyway, as it will expel hot air outside the case, rather than dumping it back inside. The difference this makes is not to be underestimated. I had to add two extra exhaust fans to my Parvum when I moved from the reference 780 to a custom one.
I'm finishing off my 250d build, just about managed to squeeze my Lightning in, there really aint a lot of room to play with, it was like bloody Tetris trying to get it all in :D.
Apparently it fits card up to 295mm.
I've got mine coming over the next few days and just hope my 7950 fits which is bang on 295 :oO
