GTX 780ti Installation Problem
11 Nov 2015
So I had two EVGA GTX 780ti cards in SLI and everything was working well, then one card failed so I opted to buy a ‘new’ one from ‘the bay’.
The new card arrives, powers up but Windows 10 won’t install the driver, just end up with spinning dots on the boot screen, and I let it overnight so it’s definitely not working. I then opt to rebuild my PC using the new card to check if it’s working. When powered on you get the BIOS display etc, install Windows ok until it the graphics drivers are installed, then a blank screen. On reboot I end up with the spinning dots again. I’ve tried the rebuilt several times with the same result. Trying the same process with my existing GTX 780ti there are no issues, the install goes though without issue.
My question… does anyone else think the new card is ****** ?
