Hi, my current system is old and as follows:
CPU: Intel Core i3-2100 Processor (3M Cache, 3.10 GHz)
Mobo: Asus P8H67-M (1155 socket)
RAM: 8GB Corsair DDR3 Vengeance (2 x 4)
PSU: OCZ ModXStream Pro 600W Modular
GPU: HD4850 Gigabyte 512 ddr3 (23.5 cm long)
Case: Antec P180
With Windows 10 on the horizon and me being locked out of modern and DX12 games, I felt it was time to upgrade the GPU.
I mainly play on a 19" 1440x900 monitor and usually in windowed mode. But I am entertaining the idea of occasionally playing on a 42" 1080p TV, thanks to a 20m HDMI I just bought.
I was certain I'd get the 960, and I'm still strongly leaning towards it, because it's supposedly very quiet, power friendly and affordable.
However, I've been thinking for £100 more, I could basically get like double the power - and I hear the 970 is relatively quiet/ power friendly as well(?)
However, I kind of feel the 970 might be overkill given the fact I'll mainly be playing on this small monitor, and also, the rest of my PC isn't that high-spec.
Another slight issue is that I fear the 970 may not fit in my case; I have an IDE drive next to where the GPU comes to and it can only fit about 24.5 cm. If I were to move the IDE drive elsewhere, it could fit a 30 cm long card at max. Also, not sure if my PSU would adequately power the 970. I have 1 6 pin free and have nothing plugged in to the 2 red 8 pin ones.
So, at a crossroad and wondering which one to get.
Thanks in advance.
Case: Antec P180
Thanks in advance.
