GTX 960M Problems.
23 Feb 2010
Hereford
Hi guys. I have a Lenovo Y50-70 laptop with the above gpu in it. Every now and again, I get really bad screen flickering and blinking. I assume it's a faulty gpu. Also in afterburner, my base and boost clock skyrocket for a second, and then go normal again whilst i'm sat in idle.
Also the temp readings go up and down in the graph constantly, from a normal temp, down to 0, and back up again. Can somebody please shed some light into what's going on? Thanks.
Before RMA the laptop I would uninstall the Nvidia drivers then boot in to safe mode and use display driver uninstaller. Reboot and install the latest drivers.
Does your laptop use onboard graphics when not in 3D mode (ie gaming)? Is so make sure your using the latest driver for your onboard.
