gtx 970 with dedicated card
25 Jul 2012
hello,
i would like to know does it pays off if i have with evga gtx 970 ssc dedicated card for physx evga gtx 650 ti boost 2gb ( from old build ).
or there is no difference at all ?
thanks
It would be entirely down to how often you actually play PhysX titles.
For example if you were playing Batman series Marathaon or lots of Borderlands, then it would probably worth it; in other times when you play non PhysX titles and won't be playing PhysX titles in a good while, it would worth taking the 650Ti Boost back out for the sake or reducing power consumption and temp inside the case.
