GTX Compatibility
25 Oct 2006
Hi,
Can someone tell me if the GTX is compatible with my motherboard: Asus P5B-E.
Also will my 580W Tagan PSU be enough to power it and the rig in sig with 2 sata hard drives, and one dvd combo drive?
I moved the hdd cage up in my TT armor jr to allow room for the gtx.
I hope theres enough room for it now.
Get some compressed air while you're at it ;)
Edit : is that the OCUK Value 512mb 7900GS? The Palit one? Looks like mine ...
Im sure ive seen this before, and i said yes, GTX will be fine on your board, and the PSU will be fine to power it all to. :p
Nope that was GTS :p The new deal released today made me do some changes :D
Need to find somewhere that does compressed air for a reasonable price. The card is the Palit 7600gt Sonic
Loads of room there, the only thing that might get in the way are the cables.
I will sort the cables when I get new card :)
Thanks for all the fast replies!
Hey stopsign,
Just to clarify:
8800GTX, quadcore, 4gb ram, P35 mobo, 2x hdd's and an optical drive... all ok on the Tagan 580 watt psu.
gt
