GTX260 SLI Question
10 Jan 2009
I have a factory overclocked XFX GTX260 Black 65nm 216 core - how close a match do I need to go SLI without any problems? I'm particularly wary of the fact that the 65nm versions are scarce these days...
Cheers
that would be awesome. Do I need to be careful about setting them to the same clock speeds etc? Is there anything else to consider to get the best result?
They _should_ try and match clocks to the card in the primary (closest to CPU) slot but theres no guarantees - unless you know they will both overclock to the same level fine its best to put the slower card in the primary slot...
Use GPU-Z to check they really are running the same clock speed - if they aren't it can lead to "microstutter".
You can mix and match 65nm and 55nm fine - but I'd try to get 2 cards with the same number of SPs if possible.
In my gaming rig I currently have a BFG 65nm OC MAXCORE (216SP) and a Sparkle 55nm 216SP and it works fine - the sparkle actually overclocks better than the BFG OC :( by quite a margin.
cool, thanks.
Yeah I'm a bit disappointed with my card - I was hoping to overclock it more but in fact I had to detune it to stop games continually crashing (666Mhz to 600Mhz). It's still better than standard but proabably nowhere near as good as a standard card that can overclock well!! Is microstutter the only thing thing to worry about with this sort of setup?
I've never had any microstutter issues with SLI except when the cards (for whatever reason) were running ~15-20% or more difference in clock speed.
You should be able to get the core up higher (tho the shader clock is where a lot of the performance comes from) by dropping the shader clock down a bit in unlinked mode... tho the crashing issue with 200 series cards seems to mostly come from something not getting enough airflow - possibly the VRMs.
