gtx280 bottlenecked
I run 260GTX with a e6700 @ 3.2 which is about as high as the vidcard needs, going higher gives no appreciable performance increase at all that I can see.:)
I did some perf tests on mass effect and dawn of war, despite it's age dawn of war is quite graphically demanding on the 8 player maps particularly when the screen is full of troops
I did both CPU and GTX overclocks, the CPU ones made no real differance that i could notice
The GPU overclocks, made it marginally smoother in the area's i got the odd stutter or drop below 60FPS, i tried CPU speeds from 3.16 stock to 3.8 on a dual core, 3.2 or there abouts is all you need and you will get more perf by overclocking the card over the CPU in most games
