After upgrading to a HAF case, I have noticed that my GTX280 is running much hotter than it should be. It's about a year old and has gathered some dust over that time. It may have been running hot in my previous case (Antec 900), but im sure the fan wasn't as loud back then. It easily hits 80-90C when gaming, putting the fan on 100%, which is incredibly loud.
I just did a test using Furmark, at stock it reaches 97-98C after 15 mins, however with the side off it goes down to 93C. Is that right? If so i'm quite disappointed with the HAF airflow because it was meant to be really good. Is there anything I can do to reduce temps? I thought about taking off the heatsink and putting it back on with AS5 instead. How easy would this be?
Thanks for any help.
EDIT: Just FYI, it idles at 54C at 40% fan.
