GTX285 and low power mode
11 Dec 2003
Hi all,
I've recently been keeping an eye on temperatures on my rig using Everest. At idle my GTX285 hovers around 42-45 and can go up to 70 max when gaming, this is using Rivatuner to create some custom fan profiles. However, after playing Batman Arkham Asylum yesterday for a couple of sessions I noticed that each time the card wouldn't go lower than 55 when idle on Vista desktop. It stayed like this for an hour or so, I restarted and low and behold it started dropping back to the more usual 42-45. Its like the low power mode isn't kicking back in after the card has been used to play a game.
Just wondered if anyone has encountered this before? Is it a Vista issue? Nvidia driver issue (i'm using latest drivers btw) or possibly something to do with Rivatuner? Any ideas anyone?
Thanks for any replies.
Specs:
Asus Maximus Formula with E8400 @ 3.6 and Akasa Nero Cooler
BFG GTX285 OC
2xSATA HDs
Corsair 620w PSU
Akasa Zen Case
Vista 64 SP1
When I had Vista for a brief period my Nvidia card would stay at the 3D speeds until I restarted.
You can check with Rivatuner to see if the clockspeeds go down or stay at the 3D speeds.
OK so its looking like its a Vista issue, hopefully upgrading to Windows 7 soon will cure the problem. Thanks for the reply Dutch Guy.
