I've got a Zotac GTX285 (standard GTX285 w/AMP bios flashed) and it fully loads at 85c. I was wondering if I can get this down a few degrees without forking out £40 on a new cooler.
So my question is, can I take the cooler off and apply AS5 to all the bits that have a thermal pad on? or is the pad bridging a gap? ie. if I apply AS5 to certain parts will it even come into contact with the heatsink? Is it worth buying some thermal pads if so, or will they be re-usable, they aren't sticky are they?
Ta
Ta
