gtx460 sli
8 Sep 2010
South Yorkshire
Hi i already own a Palit 460 768mb and want to get another 460 later on when i get my new sandybridge setup.
I am wondering if i can get any brand of gtx460 to go with my palit in sli as ocuk doesn't supply the palit one anymore.
Thanks
Maybe. You may experience capacitor ageing meaning that it would not be able to power the 460's.Any brand will do fine as long as the speeds are the same. otherwise the secondary one clocks to primary ones speeds. Make sure that you card manufacturers will give you an RMA for a card damaged by insufficient PSU. I know EVGA do
Yes u can sli mur card with other manufacturers of ur card but u cant sli with a 480 or 470 as there a mopre powerfull card hardware wise.
Your tagan power supply should be fine for sli with ur 460's
