- 15 Jan 2011
Hi
I am looking to build a new Pc for gaming, but I am on a tight budget of around £575. A friend sugested the GTX460 1GB, but this does not fit into my price range,
However the GTX460 768Mb Superclocked does just about fit. Is it worth me getting the overclocked version, or should i just go for the non-clocked?
here is my current build: http://i.cubeupload.com/fj1ALg.png
I am very, very open to any of your suggestions as to what I should change/ improve and where i should be looking to save money. (i realy cannot afford to spend ANY more than I currently am.)
thank you for your time.
