I have now 2x GTX480, played a bit in sli, decided that borderlands doesn't really need SLI to run perfectly all maxed out.
So i went and disabled SLI and not using the second card for Physx.
So, if the second card is not used at all, why its temps rise from 42 idle to 70 while i play Borderlands2 ? GPU usage is zero, but temps constantly stabilize at 70... ??? What gives ? If there is temp rise there has to be power consumption rising as well...
Case is Antec900, well ventilated.
Cards are one space apart, which is occupied by sound card.
Temps, fan tach and GPU usage monitored by MSI Afterburner...
Is there a way to completely disable second card without actually pulling it out ?
#EDIT1#
Well, i have a theory.
This problem persists in games that are built on Unreal Engine or drivers in regards to UE.
I'm now in a process of testing different games.
Unreal games (that heat up GPU2):
Borderlands1
Borderlands2
Batman Arkham City
Non-UE games (that don't heat up GPU2):
Skyrim
Just cause2
Torchlight2
Far Cry2
Portal 2
Still testing. Have to install some of my steam games to do that. Will keep updating...
#EDIT2# **SORTED** Disabled CUDA for one of GPUs (global 3d settings) and temps went back to normal...
#EDIT1#
Borderlands1
Borderlands2
Batman Arkham City
Skyrim
Just cause2
Torchlight2
Far Cry2
Portal 2
