I had the same thing once. It only happended in games. It turned out it was my monitor. I would borrow a monitor to test things if you don't have a second one of your own.
Any other machine/videocard/monitor to rule out each component?
During a game, there are constantly horizontal lines on the screen creating a ripple effect. When im not playing a game this goes away, what could be the cause?![]()
I had this effect with a Sapphire graphics card many moons ago. Had to RMA it, faulty card.
It was evident from new. Has yours always been like this, or is it a recent event?
Ive had this problem before, it seemed to happen because of a vga to dvi adaptor. We have almost 2 identical samsung monitors in this house, one with dvi and one with only vga. Had this problem on the vga monitor using vga to dvi adapter but not on the dvi monitor, With the exact same system.
I swear i read somewhere that blue dvi ports are vga to dvi friendly and that white dvi ports are not? but I cant confirm this.
Problem is most likely you need a digital monitor whith a dvi or hdmi port.
Time to save for a new monitor then![]()
Yeah probably a good idea, but just to be safe if you can get a hold of any sort of monitor/tv with a digital output try the pc on that first to see if gets rid of the problem. If it does then you know for sure you just need a new monitor.
