Hi guys,
Several months ago I bought this card from OCUK:
https://www.overclockers.co.uk/showproduct.php?prodid=GX-130-MS
Currently it is out of stock but there are other MSI GTX560Ti 1gb cards that are available. The problem is these cards have different core clock and shader clock speeds. When connecting the card up to my current one in SLI will it work?
Am I right in thinking as long as its the same model of card (i.e msi gtx560ti) and has the same memory (1gb) it should work fine and both cards will just run at the settings set by the lesser spec card??
Thanks
Thanks
