GTX570 HDMI Output issues
Man of Honour
17 Oct 2002
Hi guys,
I have bought a 3 into 1 HDMI switch. I have connected my GTX570 into one of the Inputs, a PS3 into the other, and the output is an HDMI-DVI cable which goes into my monitor.
When I first boot windows with the switch set to the PC, it works fine.
I then switch to the PS3.
If I switch back to the PC, the monitor displays an out of range error message. The only way to get the picture back is to reboot Windows, where it will then work fine until I switch away from PC and then back again using the switch.
Any ideas? Crappy switch? Or something else?
Long shot Fox but I don't suppose you have another card you can try? Preferably an ATI one (this isn't a jab at nVidia, I just thought you could eliminate driver bug this way).
If it still happens, i'd suspect the switch, if not then it's going to be a driver issue.
