GTX570 WC
5 Nov 2011
Gloucestershire
Anyone got a KFA2 GTX570 under water? Some variants of this card are ref design, but I'm worried mine is not. Sadly the one I bought did not match the picture on EK's cooling configurator site :(
Any ideas?
Gloucester. :D
Sadly I don't think they were reference. :(
EDIT quote: 'KFA2 manufacture their own graphics cards, unlike some card partners who simply slap a sticker on the cooler and call it their own. You will not find a reference graphics card hailing with the KFA2 tag either and as you will see with today’s sample, their designs are strikingly different from the usual, reference designs.'
^According to CC the only KFA2 & Galaxy 570's they list are full NV Ref design...
KFA2 also make reference 670, 680 etc...but yes their custom cooled 'OC' edition cards are usually on a custom PCB.
@OP, Simplest solution would be to take the cooler off and show it to EK tech support, they should be able to tell you if it will work with any full cover blocks.
I don't think this is an OC version. There is a KFA2 on cc but the image of the cooler doesn't match my actual cooler so that's why I'm dubious. Thanks for replies guys!
