- 15 Jun 2012
Hi,
I bought my EVGA GTX580 SC in march along with the rest of my rig (from OCUK of course!) and have been using it at stock clocks since - and a very fine job it's been doing.
Recently, I read a couple of guides and began to overclock it using EVGA Precision X.
I started increasing memory clock in 50MHz increments, testing using EVGA OC Scanner as well as Furmark. I was doing 5 minutes of the Furry test. 5 minutes of the Tessy (Tesselation?) test in OC Scanner followed by 5 minutes of Furmark at full screen with 4x MSAA
I then started increasing core clock in 25MHz increments, testing similarly, but using no AA on Furmark (following the reccomendations of a guide).
I reached a maximum of 900MHz core and 2350MHz memory after the tests crashed the display driver and I reduced the core clock. Thinking all was well, I tested using Furmark for 15 minutes to make sure the clocks were stable.
Throughout testing, temperatures were around 70°C, maximum of 75°C during the Tessy test. I did not change the voltages or any other setting s on the card, either.
I then proceeded to play a game (Skyrim if it matters). Played fine for around 5 minutes before the screen glitched out and the display cut off. When it returned, I noticed the clocks had returned to stock. Similar things happened in other games (Crysis, Borderlands) but only when using the upped clocks. Even reducing the clocks to just above stock to around 825/2100 still caused the problem.
This obviously means that the clocks I set aren't stable. If not, how were they able to pass all the tests without fault? I was lead to belive that Furmark was just about the most taxing thing you could do to a card.
So, I would really appreciate any advice on my problem. Is my testing method flawed? Should I be testing just using games? Also, what kind of clocks have other people achieved on similar cards? Mine seemed about right from what I read on various forums - but if they aren't stable, what's the use!
Wow, I've been rambling. Sorry for the wall of text.
Any help would be great,
Thanks.
Thanks.
