Hi
I have had delivered from here a B-Grade Gigabyte GTX670 (GV-N670OC-2GD)
to install I uninstalled ccc (from old GPU's) removed cards and then installed this one. I checked the Bios using Gigabyte VGA @BIOS and all correct.
I installed the Nvidia control panel from the Gigabyte website rebooted. Froze one so I then downloaded the update from the Nvidia site.
Since then I have had a couple of freezes. The first whilst playing a game and watching a film on the 2nd monitor. The other just browsing and watching the film.
This is annoying. The only thing that has changed is removing the CF 4870's and replacing with 1 GTX670 and swapping the software.
Any ideas what is causing this? could it be a faulty card hence B-Grade? The box was pretty battered and screwed up antistatic bag, but all the coverings for the contacts where present & correct.
