Hi,
I have couple of issues with my PNY GTX780 XLR8 OC. It run without issue up to few weeks ago. Over the last 4 months I have the card on stock speeds, because is powerful enough and I do not need the extra overclock.
a) When I start the system, I need to reboot. The reason is the EVGA Precision and the MSI AB, do not show all the information of the card. (eg the Link, low speeds).
And I know it will crash as soon as I start a game, requiring a reboot
b) After the reboot, it all works ok. However, there are times when the driver crashes. I have pretty aggressive fan profiles (60C 100% fan), cleaned the cooler however still overheats to 70C and crashes the driver. It idles at 38C at 54% fan speed.
Case temp is 20C and I run open case either way. Where 4 120mm fans are pushing cold air into it from the H100i radiator with high pressure also and the airflow is passing over the graphic card also. (the air is cold)
Maybe I need to remove the cooler and replace the thermal paste? Or is there a case there to return since it is in warranty? (bought it late November 2013, however i have no second gpu to use my PC)
I am happy with the card, is very powerful, relative quiet and had no issues with it until now.
