- 20 Jun 2011
Hi,
I'm considering upgrading my graphics card(s) to a GTX780ti and was wondering about the video outputs. I have two 560ti's (in SLI) at the moment and as I'm using three, 32" LCD TV's as displays, the cards are connected via HDMI using DVI-to-HDMI adapters.
Can I do a similar thing with the 780ti? i.e. run two displays from the DVI outputs (using the HDMI adapters) and the third directly from the 780's HDMI port? Is that possible or is there another combination?
If it helps, here are the current system specs (the build is nearly three years old now):
Thanks!
Code:
2x Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card
Intel Core i5-2500K 3.30GHz @ 4.80GHz (Sandybridge) Socket LGA1155 Processor
MSI P67A-GD65 Intel P67 (socket 1155) DDR3 Motherboard ** B3 REVISION **
Crucial RealSSD M4 64GB 2.5 SATA 6Gb/s Solid State Hard Drive
XFX Pro 750W Core Edition '80 Plus Bronze' Power Supply
Kingston HyperX Genesis Grey 8GB (4x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Microsoft Windows 7 Bundle - Home Premium 64 Bit
Thanks!
I paid £419.00 Running this on a 2650x1440. Up graded from a CF 7950 MSI twin 980mhz stock
