Hi,
I was hoping someone might be able to help, I keep getting this on odd programs where it doesn’t display right I've tried it in compatibility modes and changed resolution around but still nothing seems to fix it
I've removed .Net frameworks with the cleanup_tool,
Restarted PC,
Tried it again still same issue, reinstalled .Net from a direct download rather than update, still same issue.
As you can see its not actually displaying correctly in the box more as if it’s been pushed down a bit and it does this on diffrent programs on install or settings page for things you can resize the window for.
Restarted PC,
