GUIDE: Get the FOV of eyefinity on a SINGLE MONITOR!
31 Jul 2009
This is a guide on how you can set custom screen resolutions with very high aspect ratios so it gives you a very high FOV (field of view) like eyefinity.
You do not need a 5000 series card to do this, i am using my HD 4870
Requirements:
- A monitor connected via DVI or HDMI for full screen mode (DO NOT USE VGA!). If you have VGA connection, PLEASE MAKE SURE the game is in 'windowed' mode
-The monitor needs to have a 'keep aspect ratio' option or something similar. My cheap Hannspree one does so I assume most monitors have them.
- Ati graphics card and Ati catalyst installed (might work with Nvidia cards but I do not have one to test it with)
The guide will be in my second post
What is FOV? Well I will demonstrate it using Crysis below (yes I haven't goten very far yet).
Crysis at my native resolution 1920x1080, aspect ratio 16:9 :
Full size: http://img684.imageshack.us/img684/6106/25292968.png
Crysis at a custom resolution 1920x720, aspect ratio 16:6 (8:3) - same as two 1440x1080 monitors in eyefinity mode (2880x1080):
Full size: http://img143.imageshack.us/img143/1341/37102717.png
Crysis at a custom resolution 1920x540, aspect ratio 32:9 - same as two monitors at 1920x1080 in eyefinity mode (3840x1080):
Full size: http://img295.imageshack.us/img295/7206/52259756.png
As you can see when you compare the screenshots, the higher the aspect ratio, the more/wider you can see.
As for how it actuall looks on my monitor,
1920x720:
1920x540:
This trick only works properly with games that support eyefinity/abnormal resolutions. If you try it with others that don’t, the image will just be stretched.
NOTE: You can already set custom resolutions using catalyst but it is limited to 1280x720
The guide:
1. Open the CCC and navigate to information center
2. Right click on the 2D Driver file path and click copy selected.
3. Paste it in somewhere like notepad, microsoft word, etc…
4. Navigate to that location in the registry
5. Scroll down until you see ‘DALNonstandardModesBCD’. There are 4 of them. BCD1,2,3,4
6. Just right-click anyone (I used BCD1) and click ‘modify’. This brings up a table-like structure that looks like this:
7. This is where you enter the custom resolution you want to set. ONLY USE MULTIPLES OF FOUR ie 4,8,12,16 etc…. Enter it in the following format: The first 4 digits on the left cannot be edited, they are just identifiers. The next 4 digits are the width, the 4 after that are height. The last two digits set the refresh rate. Put zeros for everything else.
* The width should be the maximum supported by your monitor and not any higher. ie if your monitor's maximum width is 1680, dont go putting 1920
8. Example If I wanted to set a resolution of 1920x540 at 60Hz I would type: ‘1920054000000060’ The spaces are put automatically.
9. You can press enter add as many as you want. I also use 1920x720 so that is entered as: ’1920072000000060’
10. Once you are done, click ok and restart your computer, fire up a game and the resolutions you created should be selectable in the game
Wait, what, am I missing something, you're shrinking the res, making a slimmer rectangle, are you not basically creating black bars on the screen and basically lowering the effective resolution, making it somewhat pointless?
Eyefinity is also supposed to mimic peripheral vision to some degree, you're not supposed to have a larger FOV in the same area as before, you're supposed to have more area.
Whatever you gain doing this in weird/odd peripheral vision on your single screen, will surely be canceled out in terms of improved visuals, by the squashed height/resolution vertically?
Yes eyefinity does mimic peripheral vision to some extent but thats not what I'm concerned about. All I care about is the increased area in which you can see more, which can give you an advantage when playing online or even single player. I see it as cheap eyefinity
That's quite a good idea, I like it. Can I ask two things though. Could you resize your screenshots please to make them easier to view in the browser and can you do some screenshots that include the black bars so that we can see how that looks?
Also, do you mind if I post this in another forum (can't link to here)?
Cheers.
kinda pointless because with the 32:9 option you're essentially going for 25% of the pixels you'd get if you just bought another monitor
so although you get a larger FOV, 4 pixels now equals 1 so the quality will be extremely bad in comparison and stuff which is in your field of view may be no where as crisp
Cheers.
I've resized the images and included pics of how it actually looks on my monitor (windowed mode). I wouldn't mind you reposting elsewhere as long as it links back here
I'd say try it and actually see how it looks like in person before slating it. Also as for quality, there is no difference because the pixels are specific to the resolution you pick. Its not a single image that gets enlarged/shrunk. That said, I do use the 16:6 more often than the 32:9
ok, I tried it, it looks horrible
everything looks way too thin, and because of the low resolution there is now very visible aliasing, the picture is enlarged because it has double the pixels vertically
edit: nvm see what you did now, honestly I couldn't play like that even with my 27.5" screen, to many distractions
Ahh I get what you mean, your monitor stretched everything to fill the whole screen. There should be an option in the monitor's menu for you to keep the aspect ratio and you end up with black bars instead. Something like this
tried it on my dell 24" ultrasharp,native is 1900x1200 so what works for me is 1900x600 or 1900 x 400,ill just have to install a game that is supported properly,at 1900x600 half my vertical screen is gone and at 1900x400 2/3s gone so realistically its only good for screen shots,recording movies or to test if eye infinity is for you.
i tried with gtr2 as the fov can be adjusted from 30 to 100 ,40 looked great ,100 you see all of the side windows but cars either side are stretched and your perspective makes it a lot harder to control the car.
Ill stick back in shift as that is a supported game and see what it makes of it
Nice tip though Temi_D
for nvidia there is no need of all that editing you can set custom resolutions ,however i had to apply them by right clicking the desktop and select screen resolutions there.
1900x720 works as well.
Works fine the 1920x720@60 showed up in BFBC2.
However, I then had to hunt around for a way to get ATI to let me use "fixed aspect ratio" with my HDMI 1080p.
After I got that sorted with ATI GPU Scaling Fix v1.1
www.ultimate-filez.com
Then I found my new Asus ms238 LED-LCD only has "full", "overscan", and a greyed out "4:3" anyway no way to force the monitor to go fixed aspect ratio or 1:1 so in the end I cant use the trick but got really close so thanks anyway.
Maybe it will work with another game.
